spindrift wrote:
3Fivers51 wrote:
Ok spindrift, what do you suggest or what is your take on this? I also got a lot of information from a cooper tire rep.
Thanks for your impute it is always a good tool for guidance!
Bill
I believe you should have a load inflation table from your tire manufacturer, properly weigh your rig and then inflate your tires to the appropriate pressure based upon the manufacturer's recommendation.
This is a simple truth. Tire manufacturers
do not set recommended (correct) tire pressures. Vehicle manufacturers do. So the correct recommend tire pressure for your tires is found on the vehicle's federal certification label for all original equipment tires and any replacements that are the same size and design as the OE tires.
FE
