Goodyear Tire and Rubber .... weighing RVs website.
Special Considerations
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up."
and from;
rvsafety.com
Tire Load and Inflation Ratings
Note: Towable – Travel Trailer/ 5th Wheel owners Due to the severe use conditions experienced by tires when axles are very close together – tire industry experts recommend maximum (sidewall) inflation pressure for towable tires unless this causes a sever over-inflation situation (20psi+), often referred to as the ‘basketball effect’. If this is your situation allow a 10 – 15psi safety margin above the minimum required inflation pressure."
And this from Tireman9 one of our resident tire engineers who says this about RV mfg setting tire pressures;
"The manufacturers do not take into consideration the side to side unbalance, as to do so would require them to provide larger (more expensive) tires. The other thing RV industry does not take into consideration is the forces to the tire structure due to running close axle spacing. Engineering analysis shows that when turning corners the forces trying to tear the tire apart can be over 20% higher in multi-axle applications than with tires at the corners of the vehicle.
The only options for the trailer owner are to up-size the tires (if there is room) or up-rate and increase inflation (if a higher Load Range tire and stronger wheels are available). Lacking the above being sure to run the tire at the inflation shown on the sidewall (i.e. max) will slightly decrease but not eliminate the overload forces." end of quote..
Tire pressure numbers on a placard are a recommendation only and is not the last word in the best pressure for the tires on any vehicle and especially a trailer.
Many trailers out here don't have a tire placard. We learned the hard way what pressures worked best and which didn't.
