garysol wrote:
5th wheel is a Komfort 3530 40ft bunkhouse
GVWR is 15,500lbs.
Wheels are 16in and rated up to 110psi.
Making a few assumptions here since I honestly have not weighed the trailer but lets use the GVWR of 15,500 and the 20% pin weight "rule".
pin weight 3,100
wheel weight 3,100 x 4
I have pretty much narrowed my decision to Maxxis m8008 and the Goodyear g614.
Maxxis m8008 ST235/80R-16= 3,420 max load and $160.00 x 4
Goodyear g614 235/85R-16= 3,750 max load and $320.00 x 4
Assuming you owned my trailer and were not swimming in money which tire would you choose?
Not even a contest. Don't even consider the Maxxis. Either go with a G-rated tire or, at minimum, Michelin Ribs or Bridgestone Duravis R250.
Lyle
