tomthyme's avatar
tomthyme
Tire lifespan
Hello Folks,
First, thank you to all the veterans and families of veterans out there.
On a run from Hot Springs today, we experienced our first blowout! We are grateful that no one was hurt. We are also grateful that we were able to limp on the shoulder about 1/2 mile and pull slowly into a TA travel center without incident.
Once there we learned that our 2011 Cameo came artfully equipped with a lug wrench that diid not fit. Again, grateful to find that the travel center we pulled into had a roadside assistant (for big rigs) so the tire swap was rather fast.
About 2 years ago we outfitted our rig with the G614 product from Goodyear (4 plus the spare). Once the spare was installed I was very surprised to see the tread wear vastly different between the 'new' spare, and the tires on the ground. These tires have made runs between Dallas and Austin, a rub to Colorado Springs, and a few runs to Hot Springs from Dallas as well. All in all, likely less than 10k miles. Shouldn't these hold up a bit better? I have been diligent about pressure, etc., but I am curious as to other experiences with these tires.
Please feel free to chime in if you have another experience or brand too. We are trying to figure out next steps for the other tires too.
Thanks all.
Thanks
  • Have you checked your spring hanger shackles for wear,usually wear oblong where the bolts run through and will put your axels out of alignment, a wet bolt kit will fix it up,if thats the issue. The G,s are a great wearing tire, mine were in use for 40000 miles /6 years on a 14700 lb fiver before we replaced them.
  • The alignment advise is good. Other question is do you perform a lot of tight turning? With your travel patterns your tires should be replaced due to age before they ever wear out (5 years).
  • You might want to have a real trailer service shop check the alignment on your axles. I put about 10k miles each a Horse Trailer, FW, and Utility trailer yearly. I've never come close to actually wearing out a tire in 12 years. I do put new tires on the trailers every 3 years due to age.
  • What was the date on the tires....how fast do you drive.....how much does each tire support (weight)....what max wt and max cold tp....you need to put a lot more data in your post.....
