Because people like lists, I made 2 .
it gives advice pressures from 5 to 155psi at 65 degr Fahrenheit.
And then from below freesing temp to to warm for driving about 60m/h.
Idea is that you measure the cold pressure of tires and determine the ambiënt temp at that moment.
Then look in one of the lists to see what this would be at 65 degr F.
This should be the adviced pressure by the tire maker or determined by calculation.
Then when driving about 60m/h the temp inside the tire rises aproximately 110-65= 45 degr F above anbiënt temp at that moment.
If so your pressure is not to low so tires wont get to hot so they damage.
When ambiënt temp is higher then 65 , the cold measured pressure ( when tenp inside tire= outside tire) you need higher pressure as given in the list for that ambiënt temp to give the tire a warm inside tire temp of about 45 degr F higher then that ambiënt temp.
The pressure your TMPS gives must be when driving at about 60m/h the pressure belonging to the temp warm.
Here the 2 lists
And for the lower pressures
EDIT
And again from the storing site nex poster Barney S gave.
Having problems myself too, one time I see the pictures, and an other time I dont, must be somenthing with the savety settings of the Onedrive of hotmail adress I store my pictures .
