EgorKC
Sep 11, 2016Explorer
tire pressure monitor
Pulling into the RV storage lot after a long weekend the alarm went off. Looked and it indicated a tire (2 year old Marathon) was losing pressure. As we have to pull around an RV service building to get to the lot I suspect I ran over a loose screw. The tire lost about 15lbs in the few minutes it took to unhook but that was not enough to show visible signs and the tire was not hissing. Had it not been for the monitor we would have stored the trailer and gone home unaware. We would come to pick it up next time to find a flat. As it is we arranged to have it fixed (replaced most likely) by the repair shop there. If you do not use one I recommend you at least investigate them and consider it.
Greg.
Greg.
