TNSnowbirds's avatar
TNSnowbirds
Tire Pressure/Temp Monitoring System
We just bought a new 5th wheel (Bighorn) and I want to install a monitoring system for the tires. I've searched a few websites and found that there's several versions of systems available but have no idea which one may be the best to purchase. I'll appreciate any info you guys can provide. Many thanks, Tom
  • MSGTRETIREDCSP wrote:
    I've been using the TST system. I never thought I needed one as I've never had a problem (until yesterday). I had just come off Monarch Pass on the west side when I got the alarm and it showed my right rear tire was at 65 lbs and rapidly deflating. I found a wide pull off about a mile down the road before my air was down to 35 psi. Yep, my China bomb tire had lost part of it's tread and the tire was trash. I got the tire changed and I was on my way - no damage. I'm sold on them now. Good luck in your selection, there are many good ones out there.
    Had a similar experience with our TST model 510 system a few years ago. When all my sensors were destroyed in a house fire, I took the opportunity to switch to the TST 507 model and for the trailer added flow-thru in-wheel sensors with a stated 7 year battery life.
  • Another TST user. I have the model with user replacable batteries. Works well so far.
  • Love my Pressure Pro, and great service when needed. Also simple to change between vehicles, which we do.
  • I have the tst also and now I don't look back for black rubber chunks like in the past but it still could happen. Now MSG what tires are you going to buy?
    chevman
  • I've been using the TST system. I never thought I needed one as I've never had a problem (until yesterday). I had just come off Monarch Pass on the west side when I got the alarm and it showed my right rear tire was at 65 lbs and rapidly deflating. I found a wide pull off about a mile down the road before my air was down to 35 psi. Yep, my China bomb tire had lost part of it's tread and the tire was trash. I got the tire changed and I was on my way - no damage. I'm sold on them now. Good luck in your selection, there are many good ones out there.
  • I have been running the TireMinder TMG400C system for about 3 years, it will monitor pressure and temp for up to 22 wheels. It's easy to program and use, and I like that I can change the sensor batteries without having to buy new sensors. I had a problem with the 12volt charging cord that came with the system and their customer service dept was great to deal with.
