Itried
Feb 24, 2016Explorer
Ed9824v wrote:Don't know what else it would have been...was fine before, not after. This was about a year after we got it. I'm the only one behind the wheel so I would know if we had hit something with it. Trailer was loaded for normal camping, no toys. It was tweaked in such a way that it would have been from backing into something, toed in and up. Wasn't hard to see when you got to looking at it right and didn't take long to wear the tire....3500lb axles...trailer should have had 4200's on it. I'm one of those that like a little extra capacity especially in the running gearItried wrote:Cummins12V98 wrote:
TrailerAis Plus works great, I did need a 2X under it with the TrailAir Counterpoint suspension. I would assume the same would work with the MorRyde IS.
I did that one time with a Keystone Passport Breakaway 25fq...ended up with a new axle as all the weight tweaked the axle...
must of been more than the drive on ramp, because I have had many times I have driven over things that put one tire off the ground with no damage.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
