Puddles
Aug 15, 2018Explorer
I decided that 6" plastic levelers were too hard on the tire belt... went to a treated 2x8, cut to fit closely between the wheels... cut a 45 degree angle on each end.. if more than one is needed to get level, just lay two more behind each wheel with the cut angle matching... back onto the new boards and lay another 2x8 on the original boards and then pull up on them.
By only going up 1.5" per move the boards do not move. This procedure can be repeated as many times as you want. If I can't get level with 3 boards, I look for a different site. I do carry 2 pcs of 3/4" plywood cut to the same width for a smaller lift if necessary. Carry the boards standing upright in a plastic milk crate in the truck bed.
I always wonder about the auto leveling systems that are now sold... adding stress to "Leibert" frames. :)
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
