dryfly wrote:
dieseltruckdriver wrote:
I have had a Tireminder for a year now, and am very happy with it. It isn't perfect, but I do like being able to see the tire pressures without having to touch or adjust anything going down the road.
My pickup hasn't been started in about a month and a half, and when I unlocked it to get my binoculars out, the Tireminder beeped, and let me know it couldn't find the trailer tires. It must have a motion sensor in it, but I am not sure. It hasn't been plugged in, and the internal battery was still somewhat charged ehough to give me a readout of the pickup tires.
When you say it isn't perfect, what features does it lack that you would prefer? I'm not sure about a motion sensor, I would imagine that your trailer was far enough away that it wasn't receiving signals from the transmitters.
If you look at the join date, hi newbie! ;)
I get why you commented on the trailer not being detected. It shouldn't have detected it, it's 45 miles away. I didn't mention that. The reason I mention the motion sensor is the fact that the head unit isn't plugged in to power, it is only running on its internal battery, and I just opened the door and it started beeping at me. It hasn't been used at all for a month and a half.
Regarding the features, those are all fine. It has a temp setting so I can monitor the tire temps, but that is at the end of the valve stem, and is not going to be accurate at all. As far as being accurate, as I am driving I see the pressures rise as the tires warm up just like they should. If I take a sensor off the valve stem, I get an alarm in short order. In the morning before I start driving the tires in the sun are a degree or two higher than the ones in the shade so I know it is working correctly. My biggest issue is when I unhook the trailer, it takes quite a while before it starts alerting that there is no signal from the trailer. That gives me pause. In my mind, it should report that within a minute or two at most.
So far, I am very happy with it and I am very glad I have it. Yes I would buy it again.
