Jhurk
Apr 26, 2017Explorer
Cummins12V98 wrote:Big Katuna wrote:
Probably but the safe answer is to weigh it fully loaded and look up the mfrs recommendation for that weight then add 5 PSI.
EXACTLY!!!
That's not the question the question is, is it safe to put in 80psi in a tire rated for max 95 psi. Consider the load rating for 80 psi is ok. The rim I have is only rated for 80psi and the tire mount ed is rated for 95. Tire tech says I'm fine.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
