sleepywheel
Jul 21, 2013Explorer
tire sidewalls
My 2009 Chev CC 4x4 2500HD has an unusual problem with the front tires. With the truck fully loaded at its 9200 lb. GVW weight, I find that the steer tires will roll over onto the sidewalls when I turn a corner. There are scuff marks about 1/3rd of the way up the sidewalls and on both front tires, though a little moreso on the passenger side than the drivers side. The tires are Bridgestone Duravis M700 load range E LT265/70R17 and inflated to 80 psi cold. The tires are the original factory tires and have 10,000 miles on them.
Anyone have any ideas or experiences with this problem? Should I try inflating them a few more psi and see what happens? The tires are rated for a maximum pressure of 80. I'd hate to blow out a sidewall turning a corner at a busy intersection.
