SleepyWheel wrote:
The tires are Bridgestone Duravis M700 load range E LT265/70R17 and inflated to 80 psi cold. The tires are the original factory tires and have 10,000 miles on them.
....if you have the OEM rubber-stemmed valve stems on those rims, you'd better check their air pressure rating! You may have valve stems rated only to 60/65 PSI. Check this out ASAP.
....now, back to the possible side-wall roll: I would have the front end (IFS) of that truck checked out
with your full load on-board at a reputable shop.
Good luck,
Silver-
