Ziphead2's avatar
Ziphead2
Explorer II
Jun 29, 2017
tires, tires, tires
I have a fifth wheel that I plan on replacing all the tires. I rode on Maxxis for a few years (4) but did not have much luck with the two flats in two years. I am thinking of installing ST235/80R16-10ply, Goodyear Endurance. Does anyone have any experience with the Endurance ?
  • My brother just bought 2 goodyear endurance in a 225/75/15. Made in usa and was impressed on the load range for a 15in. tire.They look good. Only time will tell now.
  • Looking at GDR website shows a 29 RS with a 10995 gvwr. This unit may come with 5200 lb axles or maybe 6k axles.
    As mentioned the best tire for that size trailer would be a commercial grade all steel ply tire like the Bridgestone R-250 or the higher cost Michelin XPS Ribs in a ;
    ...LT235/85-16 E at 3042 lbs capacity @ 31.8" diameter..
    ...LT245/75-16 E at 3042 lbs capacity @ 30.7" diameter.
    Both sizes work great on 16" trailer wheels. Use the diameter that best fits under the wheel wells (clearance).
    The Sailun S637 is a load G tire at 4040-4400 lb capacity/110 psi and is simply too much tire for a trailer that size.
    Or take a shot at one of the new gen high speed rated ST tires.
    I have a 11200 lb 5er with 5200lb axles/ 16" wheels. I would go with a quality 16" LT E poly carcass tire or R-250/XPS Rib tire and not worry for 7-10 years and 50k-60k miles.
  • I went to a light truck tire on my fithwheel best money i spent in a long time
    trailer ride smoother
    I had ST235/80/16 Goodyear went to LT245/75/16 Toyo HT
  • I've used Maxxis for 5 yrs on two different RV's with no issues whatsoever after a collective 15,000+ miles.
  • ScottG wrote:
    we're the flats the result of punctures or failure of the tire itself?
    my thoughts exactly. :h
  • we're the flats the result of punctures or failure of the tire itself?
  • No experience with endurance but recommend Sailun S637 ST235/80R16 or ST235/85R16 all-steel 14 ply tire.
    Replaced all my Towmax better known as Blowmax a little over 2 years ago and 16,0000 miles later tires are running fine with no issues. Need 110 psi rims though.
    Sure others will recommend them also.
  • The Goodyear Endurance just became available in the last few months. So far, I've seen very few reports. It does show a lot of promise though. 87 mph speed rating vs. Maxxis at 65. And they are made in the U.S.A. I'd certainly give them a shot.
