perchjerker wrote:
I use chemicals and prescribed tissue but it keeps getting clogged. After I empty it Ive noticed air bubbles out when i fill bowl with water and flush. I see this as some kind of venting problem. I just dont understand why it keeps getting clogged. When it does I stick an air hose into toilet and taNK AND CONNECT TO COMPRESSOR WITH 80 LBS OF PRESSURE. it always blows it clear, but its just a matter if time till it stops up again. Is there a chemical or something I can do without calling rotorooter ?????? thanks
What are you blowing out with 80# of air pressure. I sure would not stick an air hose down the toilet.
