enblethen
Oct 29, 2018Nomad
Make and model of toilet would help.
Most with the slide valve can loose water because of small amount of debris in slide.
Thetford sells a bent screw diver to clean the area around the slide. You can make one out of metal coat hanged sized wire. Bend one end about 3/4 inch long tail at 90 degrees. Insert this into slide area and sweep around the seal area.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 19, 2026
