MainerBobExplorerApr 08, 2016Toilet Seal TroublesMy sealand toilet no longer holds water in the bowl. I have cleaned the seal area as best I can. Anything else I can do before rebuilding the toilet? How big a job is that to do? Thanks
13 RepliesReplies sorted by NewestShow Morelots2seeinmyrvExplorerApr 08, 2016Ours was not holding water. I put on disposable gloves and put a generous amount of Plumber's Putty, silicon grease on it.After a couple applications over a week of applying it...no more leak.Cummins12V98Explorer IIIApr 08, 2016If it's the ball type buy the "complete" rebuild kit. Don't tighten the spring cartridge too tight.Diesel_CamperExplorerApr 08, 2016You could try cleaning the blade and seal, but it might be just as mutch work as an actual rebuild...
Related ContentSwitching toiletsToilet seal lube?toilet sealSani Seal Toilet SealWanting a Bidet for my Thedford toilet.
