rhagfo
Jun 21, 2019Explorer III
twodownzero wrote:rhagfo wrote:nayther wrote:
If FR has the unit then it's pretty serious. Sounds like axles are too far forward. Of course adding water, etc. to the front will help but why should you have to do that? Proper engineering is needed
Will never understand, why TH don't have axles placed like horse trailers. much closer to the rear.
This would solve the issue with being tail heavy, but could be an issue for tongue weight.
The 30' 4 horse with small living quarters trailer had about the same 2,700# pin EMPTY as our 32' 5er fully loaded at 12,500#.
If that's true, the truck in the picture is massively overloaded. It has 2000 pounds of payload at most. And if so, you answered your own question--to keep from massively overloading 3/4 ton trucks.
Yep, it sure was, or is it? the only thing supporting the trailer is the jacks under the axles so we can get the tires replaced, AND the rear axle of the TV. TV had camper package and optional 265/75-16E tires.
Dodge was very lazy in those years only GVWR on the 2500 was 8,800#, manual trans and Camper package put the same springs as the 3500 DRW (NO SRW 3500 1994 to 2002), I think Dodge could have bumped up closer to 10,000# due to the heaver springs. I will state no Air Bags or other support devices installed.
It is DD's trailer, dad convinced her to get a 2004 Dodge 3500 DRW to haul it with, combo does great.
As for Dad, we also got a 2016 Ram 3500 DRW, as getting a newer 3500 SRW would be a lateral move even with a 12,300# GVWR. Both pulled and handled great.
About Fifth Wheel Group
