valhalla360
Jun 21, 2019Navigator
rhagfo wrote:nayther wrote:
If FR has the unit then it's pretty serious. Sounds like axles are too far forward. Of course adding water, etc. to the front will help but why should you have to do that? Proper engineering is needed
Will never understand, why TH don't have axles placed like horse trailers. much closer to the rear.
This would solve the issue with being tail heavy, but could be an issue for tongue weight.
The 30' 4 horse with small living quarters trailer had about the same 2,700# pin EMPTY as our 32' 5er fully loaded at 12,500#.
5th wheels typically run 20-25% pin weight...this results in needing at least a 3/4 ton and often a 1 ton for all but the smallest 5th wheels.
A bumper pull typically runs 10-15% hitch weight. This allows moderate size trailers to be pulled with 1/2 ton trucks. If they pushed the wheels back to increase the hitch weight, people with 1/2 ton trucks would rule out their trailers...which means reduced sales because 1/2 ton trucks are drastically more popular than 3/4 & 1 ton trucks.
Of course, the downside of this compromise is hitch weight will vary substantially depending on loaded or unloaded. In a reverse of typical conditions, a truck pushing the limits may be overloaded (hitch weight) when the toy hauler is running lite with no toys.
I would be very curious to find out what the manufacture actually finds in this situation.
- Did someone mess up when calculating the weight distribution?
- Did the OP have other cargo not mentioned that threw off the weight distribution?
- Was the WDH set up correctly?
- Was there something else we can't see given the limited information provided?
About Fifth Wheel Group
