wecamp04 wrote:
The Lefthander wrote:
The "Dry" Weight of the trailer is 7,669 lbs. and the hitch weight is 1321. According to the Specs. for the truck, the maximum towing capacity is 9500 lbs.
With the dry weights once you add all your stuff your going to be right at max for your truck orjust over I would say,can your truck do it probably .I went through this when we first started out,your truck will get tired very quickly.I Upgraded to F250 diesel best thing I ever did big difference good luck
All due respect, an F250 with a diesel probably doesn't have anymore payload (exceed GVWR) than a properly equipped 1/2 ton which would be around 2000lbs.
Their are probably more 3/4 ton diesels pulling 5th wheels that are over their GVWR than those under.
