ryanb-72's avatar
ryanb-72
F-150 towing
I am sure this is not news to a lot of you but if you are towing with an f-150 check to see that you have the relay and fuse installed for charging your camper battery.
I came across this info in another forum and was less than impressed when I went and checked only to find I have not been charging my battery while going down the road.
Ford chooses to leave out the relay and fuse for battery charging for some reason. I even have the factory installed brake controller that works just fine.
The relay goes into slot #9 and the fuse #21.
Just thought I would throw this out there in case I'm not the only one that had no idea.
Ryan
