kaydeejay wrote:
SkiSmuggs wrote:
..............I ran the safety check list from the web site and the only number I execeed was the GAWR by 510 lbs. I did what Ford did and added overload springs and HD shocks. Doesn't change the sticker numbers at all, but made perfect sense to me.
"Exceeded GAWR by 510 lbs". Unless you upgraded the tires you overloaded them too, and, apart from not being a very good idea, is also ticketable offense!
I looked at the tire specs and it was well under their load rating. 65,000 miles later, I have no regrets and have had zero problems. Had the HD Payload package been available, I would not have exceeded any numbers.
While I tend to agree that most 1/2 ton trucks are not suited for FW towing, the right 1/2 ton, PROPERLY CONFIGURED, is well suited for light fifth wheels.
I have an F350 on order simply because my next fiver will be heavier.
