kaydeejay wrote:
SkiSmuggs wrote:
..............I looked at the tire specs and it was well under their load rating. 65,000 miles later, I have no regrets and have had zero problems. Had the HD Payload package been available, I would not have exceeded any numbers.
While I tend to agree that most 1/2 ton trucks are not suited for FW towing, the right 1/2 ton, PROPERLY CONFIGURED, is well suited for light fifth wheels. .............
Hmmm, most GAWRs ARE the tire limits. Do you have higher than OEM rated tires on the truck?
My sticker rates my rear axle at 6100lbs. I have 18" OEM tires rated at 3640lbs each.
