- JIMNLINExplorer III
bucky wrote:
Once again the quote monster has reared it's ugly head. NA na, my quote is bigger than your quote. :)
Back to the subject with a question for the OP. Have you actually weighed the coach? Pin and axle weights? Loaded for a trip? Until you do all of this is moot.
Good point...typical thread about weights and safety when the OP doesn't give any axle weight numbers which starts the usual arguing.
The OP combo may handle fine or maybe he simply wants a one ton DRW. If the first is the case just keep on trucking.
If he wants a DRW truck then by all means he should get one as your combo is a danger to his family and everyone on the road. :R
OP needs to give us some actual scaled front and rear axle weight numbers for starters. - Cummins12V98Explorer III
stevewise wrote:
I tow a 43 ft 15,500lb 5er with a 2014 F350 SRW. took it up through New England from Kentucky this summer with no problems.
Bring it out West and see how it goes in the mountains and winds. Little too much tail for the dog IMHO. - stevewiseExplorerI tow a 43 ft 15,500lb 5er with a 2014 F350 SRW. took it up through New England from Kentucky this summer with no problems.
gtsum wrote:
I have 2014 ram 3500 srw. It does good 99% of the time but on our 2600 mile trip a few weeks ago, I ran into 7 hours of rain and 30-40mph wind. Towing 16500 with 3500 on the pin. I weighed it and I was 100 over rear axle and 100 over truck gvwr. That, along with the mountains and feeling a bit of side to side push pull on winding roads is leading me to order a 2016 drw. Ymmv
Yep! Under NORMAL conditions your truck is fine I am sure, it's when things get out of the ordinary you need the extra stability!
You will be thrilled with the new rig! I knew the dually would make a nice tow vehicle but I honestly did not think it would be so good. - gtsumExplorerI have 2014 ram 3500 srw. It does good 99% of the time but on our 2600 mile trip a few weeks ago, I ran into 7 hours of rain and 30-40mph wind. Towing 16500 with 3500 on the pin. I weighed it and I was 100 over rear axle and 100 over truck gvwr. That, along with the mountains and feeling a bit of side to side push pull on winding roads is leading me to order a 2016 drw. Ymmv
- Winged_OneExplorer
bobandvicki wrote:
Was assured that my TV 04 f350 kg ranch PSD SB 6.0L 4x4
would be up to the task.Hate to trade it in but need to be safe. What do you think? What TV do you use for a similar 5er? Been rving 11 months a year for the last
9 years and should know better than trust the dealer.
Look forward to your input. Bob
I have a similar weighted FW. You are right on the edge with a SRW, especially depending on how much you put in the truck. I had a SRW and it wasn't bad, but it was overloaded. I decided to go DRW because I could still fit it in the garage. ;)
To me, the DRW rides rougher than the SRW when empty, but better when loaded. The SRW got pushed through corners, the DRW doesn't.
The DRW was also only $500 more. Easy pick for me. - shadows4Nomad
Op'er looking at your previous posts, it looks like you got the 5er in March. Why are you just now questioning the purchase? Has something happened? Just curious. Good luck, John - larry_barnhartExplorer
joebedford wrote:
I traded my 2004 because it wasn't up to the job. It was fine at 14000 but at 19000 it just couldn't hack it.
Our truck would be the same but a match is a match.
chevman - joebedfordNomad IIII traded my 2004 because it wasn't up to the job. It was fine at 14000 but at 19000 it just couldn't hack it.
larry barnhart wrote:
well just for fun this is our awesome rv. Chev 8560,alpenlite14,360 combined 22,920. perfect match for us.
chevman
I would have guessed your Alpenlite to be heavier. I guess your wife is not a hoarder like mine!
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
