gkainz
May 07, 2019Explorer
valhalla360 wrote:gkainz wrote:
I am an engineer, but software, not mechanical ... but raised as a farm kid and power line construction family, I learned from the school of hard knocks and common sense about things mechanical, what breaks and what doesn't.
In my opinion only, the Andersen Ultimate imposes little to no additional stresses on the 5th wheel frame and kingpin assembly than the standard 5th wheel hitch.
Unfortunately physics doesn't agree with your opinion. There is no doubt it increases the forces on the trailer frame. To give you and idea of what it is doing, take a broom stick:
- Hold it in the middle and have someone pull from just below your hand.
- Then have them pull from the bottom.
Which one is easier to hold your hand steady without any twisting?
It all comes down to if the manufacturer accounted for these forces in the design.
Your analogy is not correct regarding the Andersen hitch, which is what I said. Yours is correct when referencing a standard Gooseneck adapter. The Andersen raises the ball to the height of the kingpin, give or take maybe an inch.
I need to clarify, as the original post DID reference an actual gooseneck conversion. I was referencing the Andersen Ultimate, which raises the ball to the level of the kingpin and imparts no additional lever motion to the pin box.
However, I do agree that the Andersen Conversion would increase the lever motion and angular forces to the pinbox, just like any other true gooseneck converter.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
