HTElectrical
Apr 15, 2022Explorer
rhagfo wrote:HTElectrical wrote:
2022 Crew Cab, Standard Bed 4WD, 6.6L Duramax Turbo-Diesel V8 engine:
Max GCWR = 29,700 Single, Dual 40,000
Max Conventional Trailering 20,000 Single, 20,000 Dual
Max Payload 5,343 Single, 6,838 Dual
GVWR 12,100 Single, 14,000 Dual
Rear Gross Axle Weight Rating 7,250 Single, 10,500 Dual
You DO NOT NEED A DUALLY to safely, comfortably, or any other matter tow that trailer!!!!!!!!!!
Well it seems you are picking and choosing your numbers, a Diesel DRW will not have a 6,838# payload.
14,000 - 6,838 = 7,162 that is one stripped down gas DRW.
I took those numbers directly from the GM website. I picked the heavier truck Crew Cab.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
