SkiSmuggs
Mar 12, 2016Explorer
I used the engine braking of Tow/Haul mode, used my braks going down a mountain by braking to 10 mph below the speed limit then let it come back up to the limit before using the brakes again. Typically, I would be in 2nd gear with the engine about 4000 RPM and that works well. Not so much in the higher gears. I got over 40,000 out of the first set of brakes and a couple of panic stops were no problem.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
