Dayle1
Mar 13, 2016Explorer II
Racine96 wrote:
Can it pull it? Yes. But it won't be safe if you have to stop unexpectedly, or crosswinds hit you. Too much weight for the rear axle. Be safe, buy a 3/4 ton
I towed several different fifth wheels over 15 yrs and too many miles to count. Never had a cross wind issue because fifth wheel setups are inherently stable, so throw that concern out the window. As for stopping, any proper setup has the trailer brakes stopping the trailer and the truck brakes stopping the truck. In an emergency stop, the last thing you want is the trailer pushing the truck because of an improper setup. Bigger brakes on heavier trucks do not reduce stopping distance, they simply compensate for the heavier truck weight. Just look at the test results in any auto magazine and compare UNLOADED stopping distance from 60 mph. As long as the setup does not exceed the GAWR or tire ratings, then the right 1/2 ton will be fine.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
