Op I asked a similar question earlier. The answers you got are similar to what i got. Here is my take...first what are your abilities? How much experience do you have? Answer honestly. Next is your truck up to the task? Tires, springs, airbags these things are available to assist your trucks capabilities. After that yes you can do it but should you? Can you handle a correct sized rig let alone an oversize rig? In any case its your dedecision.Can and should are two different things. Either way be safe. The answers you have been given are all true. Some just a little harsher then others. Good luck and happy trailering
