dieseldan723 wrote:
cummins2014 wrote:
dieseldan723 wrote:
Good evening,
I have had two GMC short box trucks and used a Pull-Rite sliding hitch with ZERO problems. I am now looking at a new Dodge with a short box. The Dodge is two inches shorter than the GMC's I have previously owned.
I am open to another sliding hitch. Is there any issue with this setup that I should be concerned about?
Thank you all for your great advice!
Yes ,its a 6'-4" bed , and I have no problems towing my fifth wheel without a slider . My truck is the 2014 Ram Megacab ,same bed length as the Ram crew cab short bed. I have two hitches , my older Reese 18K slider ,that I have pretty much quit using, and the Andersen hitch, which is a fixed hitch, although it does have four different tow positions.
Having said this ,it will depend a lot on the type of fifth wheel, and the pin box position. My present fifth wheel has some very rounded front corners ,and the pin box extends out a little further then my previous fifth wheel. Although both fifth wheels did not require a slider. Both were towed with the Andersen without issue . Good luck with your choice .
Good information. We haven't actually purchased our 5th wheel yet, however we have our heart/mind set on the Cedar Creek 388DB.
I see that fifth wheel has a 18,000 GVWR ,thats pushing a SRW 3500 Ram truck as far as weight, considering you are going with a short bed ,unless are you looking at the Megacab 3500 dually , only short bed dually I am aware of ??
As far as hitches , I see you are going with the fifth prep , my Ram 3500 has the fifth prep, but in 2014 the choices were limited on hitches, so I went with the adapter frame that goes attaches to the puck system. ,to attach a standard rail hitch . I have since went with the standard rail steel Andersen that also attaches to the adapter. knowing what I know about some of the single point hitches now, I would still go, although some will disagree ,with the adapter ,and a four point steel Andersen hitch. It works well for me with a short bed .
You will get some good advice from others ,that also work well, I have been a few different ways with hitches ,and prefer what I have done. The next best thing would be, "IF" Andersen would come out with a four point hitch that goes to the puck system on these trucks .
