FastEagle wrote:
Nice to know information for owners of regrooveable tires such as the G614.
Click Here
FE
You seem to get hung up on the fact that steel ply carcass tires are generally regrooveable! Which deals with interstate commerce and laws for such use, as your link shows. Regrooving of tires is mostly done by over the road trucking companies that have their own tire shops and stock piles of tires, where they can roll a trailer in the door and back out in an hour with replacement wheels and tires, new or regrooved.
NO ONE is going to regroove a G614, XPS RIB or R250 on a RV trailer, as they will age out way before one can wear the tread down to 2/32" of an inch. Besides NO ONE is going to tie up their trailer while the tires are send out to be regrooved. Example, I removed my RIBS at 40+K miles at 6.5 years and they had around 65 percent tread left, so I sold them on CraigsList to a guy with an old Ford pickup which was his garbage hauler. He was tickled pink to get them for 200 bucks.
The 17.5 LRH and LRJ tires now coming OEM on many trailers are steel carcass tires and would also be regrooveable. Is that a reason not to buy a new DRV trailer in your mind??? My god they have regrooveable tires, one should run the other direction. I could go back and link posts where you stated that as a negative about the XPS RIB, the tire that most love and you hate, but have never used! You have never used any higher quality tire on your current trailer! You announced at one point a while back that you were getting to old to deal with tire issues and going to 17.5" tires and rims, and then changed your mind!
Your disdain of higher quality tires for trailers and promoting of cheaply made ST tires has not wavered over the years except for the short period that you planned to switch to 17.5" tires! Which makes many question your motive!
Chris
