luckyc1423's avatar
luckyc1423
Toy Hauler / Tow vehicle help picking out
Ok, let me start by saying this will be my first toyhauler, however defenitely not my first time hauling. Pulled some heavy boats.
We are selling my lake house and considering getting a toyhauler instead of a lake property since we can go where ever we want with a toy hauler. Only downside to this is obviously on a lake home your home value typically stays the same or goes up were as on a toy hauler it decreases. Also, we wont be able to tow our boat and a toy hauler because we have a big boat (~7,500 pounds loaded and 24')
Here are my needs:
1) truck: 2500 or 3500 style truck perferably newer. I will not buy a Dual tire truck simply because I will use this truck as my everyday vehicle as well, and im in sales so having a standard single row tire is much easier day to day.
2) considering I will be getting a 2500/3500 single row tire truck, what are my toy hauler options? see below for toy hauler specs I want
Toy hauler specs needed
1) Perfer to be atleast a 12' garage. I will be hauling polaris rzr in the back, a motorcycle at times, and the hope is to have enough room (12' garage should work) to put my jet ski in the RV so we can take it to the lake with us since we cant tow the boat with the RV
Note: if a 10' garage works with keeping the sliding glass doors open then maybe thats a option
2) I want a seperate garage space
3) As nice and as long as possible that will still be safe for be to drive with a 250 or a 350. I think the tow rating on those are 16k for a 5th wheel.
4) Price is not as big of an issue since we are using this to replace our lakehome. And I know most MSRP numbers are a joke, I know several folks that get 30-35% off MSRP.
I am in houston, but willing to travel to get the right toyhauler for me if texas doesnt sell it.
  • It really depends on the specific truck you get but going with a SRW 3500 I assume 4x4 and loaded means you are limited to around 14k TH GVWR. With your TH required specifications you are really going to push the limits if it can even be done.
    Based on TH description you need a dually for the weight you are going to be carrying (notice I didn't say towing) but you might find a combination that will work. With a SRW truck you will run out of payload/GVWR/Axle Rating before you ever get close to manufactures tow rating.
  • other then the outside tv (my cyclone has external speakers but no tv) I believe it clicks off all your requirements
    how about I sell you the complete setup in my sig and I'll have forks build me a new one
    with your budget i'm sure we could work something out :)
  • I had similar but different requirements
    - 12 ft garage (rzr)
    - we wanted a loft
    - wanted dual fridges
    - wanted a more upscale toyhauler
    bought a cyclone 3950; happy with the setup but if I was to-do it ahead I'd go with a stacker and a custom 5er (space craft / new horizons / forks)
    We also bought an hdt to pull the 3950 (was using a gmc 2500); I couldn't go back to a pickup. Just having the 8x9ft deck to add 2 more quads or side by sides is worth it. Just the fuel savings over the gmc 2500 pays for the insurance/license on the hdt & 5er.
  • We just got a 2015 F350 Super Duty with super cab and short bed to replace two trucks.
    It has 4170 of payload and rated to 16100 for fifth wheel towing.
    There are two trailers we are looking at, both with twelve foot garages.
    The XLR 300X12 and the Torque 312 are both within the trucks limits and have a nice amount of room.
    I'm sure there are others that would work as well.
  • Now that I think about it, a 35' motorhome plus a 24' boat might be alot to handle. thats 69'.
    I probably will stick to a 5th wheeler. so stated my criteria above, are there any nice options you guys can recomend?
  • Y-Guy,
    I looked at that as well. The issue is I couldnt find any tow ratings for Diesel Pushers.
    Can a Class A or Class C handle ~8k of a boat?
  • Buy a used Diesel pusher, you can tow the boat and then buy a trailer for the toys. That's just another thought.
  • Ok, price isnt a huge concern however buying a semi is out of the question.
    I figure I have 60-70k for a truck and 50-100k for the toyhauler.
    I thought about the idea of just purchasing a seperate tow vehicle but then I would think the added maintenance would be annoying. Added insurance, ect...
    I would really just like to stick to having one vehicle that can do it all and that needs to be a single row wheel.
    So with that said what are my options with my above criteria?
    everything i find that has a 12' garage that looks like a very nice toyhauler is overweight.
  • Since price isn't an issue how 'bout going with a dually and another vehicle to use for your sales job. The dually will allow you to get a large toy hauler to meet your needs.
    I have a MDT to tow with and use a Toyota Avalon for my sales job. The truck was bought new in 2008 and only has a little over 10,000 miles on it. I plan on it being the last tow vehicle I will ever have to buy.
    By the way the MDT is very manueverable, it will actually turn circles inside of a single rear wheel truck turning radius.
    Here's another option... A heavy duty truck (semi) with an extended frame and a ramp for your boat, a 5th wheel hitch at the rear for your toy hauler.
    Here's a resource website with photos and info:
    http://www.hhrvresource.com/PhotoPages/TruckBeds.htm
    The guy with the most toys WINS !!!
  • Other luxury wants for the toyhauler
    1) I actually need a built in generator
    2) I would perfer to have gas for the generator and for the toys built in
    3) Decent sized TV's (outdoor tv would be cool but not a neccessity)
    4) Nice outdoor stereo (or i can add later)
    5) water to hose off as i ride in alot of mud
