fj12ryder wrote:
I'm not really sure I understand your concern. Are you thinking you'll overload the trailer and exceed the GVWR? OTOH, if you do hit the GVWR, you most likely will be over on an axle because both axles rarely weigh exactly the same, so one could be light and one heavy. I have a triple axle and I have a difference of over 500 lbs. between a couple tires.
I am concerned about overloading the axles as you described. I feel there is not enough margin with 7K axles and 16.8K GVWR or even a little less than the GVWR.
Tom
