taken
Aug 30, 2015Explorer II
walker111 wrote:taken wrote:
Mine has a 14' garage and three slides and I'm very pleased with it behind my 2012 350 SRW.
Taken
What is your pin weight on your rig? You also have a triple?
Thanks
I chose my XLR for my RV as their axles slightly forward of other brands making for a lower pin weight. (I wasn't sure I wanted to go DRW right away...) As per the cat scale I'm only 2850# on the pin with my garage empty. My drive axle is right at 3550# with my hitch in and a full tank of fuel, so I'm under on my axle and tire weights. I'm also under on my truck's GVWR by a little under 500#. If I put 2k in the garage my pin drops to around 2600#.
Yes, my RV is tri-axle, triple slide, measuring 44'5' long. She's a monster but extremely well mannered on the road. The Tuson sway control option helps in that dept. too.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 18, 2026
