thundercloud
Mar 18, 2018Explorer
Replacement Battery Help/Choices/Opinions
So my 2008 Bigfoot has had 2 Trojan T-105 Plus 6 volt batteries since new (starting their 10th year of service). My current electrical system consists of a Xantrex XADC60 charger/converter (3-stage) and 200 watts of solar with a mppt charge controller. I keep the camper plugged into shore power all the times when not in use. I replenish the water in the batteries twice a year (once before seasonal use and once when we put it away for the winter) using distilled water.
I have not seen any performance loss in the batteries throughout the years of use. So I have a few question to ask so I can make some informed decisions on replacing the batteries.
1.) How can I test the batteries to see what the state of charge is or how can I perform a capacity test?
2.) Should I replace the current set with the same Trojan T-105 Plus since I got such great performance out of them?
3.) Is there an advantage to going with an AGM battery set up like the Lifeline GPL-4CT besides the ability to not have to maintain water levels? Would I see even more life out of these vs. my current setup?
Thank you in advance for your imput and just to let you know I am not interested in lithium battery opinions as they are way over price and not in my budget.
Thanks again,
David
Thanks again,
David
