thundercloud
Mar 22, 2018Explorer
work2much wrote:
Personally I would invest in a battery monitor (for any system) and do your own load test. Charge them up fully, put a load on them and see how many Amp hours the provide until you get to your low voltage shut off. ~12v rested. New these batteries should deliver 100 AH or so for the pair to 50% SOC. (12v) If you are close the batteries are still good to go. Even if they only give you 80AH there is still life left. It would be odd for the batteries to be working fine one day and quit the next.
I do have somewhat of a battery monitor from my solar charge controller. It gives current battery voltage along with amps charging and amps of the solar panels. I will plan on doing a load test after our trip to Zion NP next week and get a better feel for life left in the batteries. Thank you for your help and suggestions.
