ticki2
Mar 21, 2018Explorer
Kayteg1 wrote:Looking at the discrption of that tester it measures CCA only even for deep cycle batteries . It does not appear to measure AH capacity .
New technology is amazing. After decades of dealing with load tester, this gizmo tells you actual capacity.
I wonder why with huge solar system you keep your camper plug in?
Something is not doing good charging job if you have to add water so often.
Solar battery tester
Battery choice is always a dilemma.
Having several cars, for TC I just use car battery. In the past I bought cheap golf-cart batteries from Sam's and they lasted me over 10 years. But I had top-end inverter/charger and remember adding water every 5 years.
