HMS_Beagle
Mar 21, 2018Explorer II
The only way to capacity test a battery is to capacity test it. That involves putting a known load on it and measuring the time to discharge. This is a device that does just that. It will test at discharge rates up to around 8A by itself, or much higher with the accessory load, but 8A is a realistic test for most RV use.
