- TWZMYJPExplorerI spent years loading Jeeps into a couple of different toy haulers we had. Just used a pair of 2x10 planks to help distribute the load, never had an issue...
- hvacExplorerI think our ATC is 4klbs. But a video is out of them driving a forklift on one at the factory. It was I think 6klb. It held.
- dsraceExplorer IIfor the vast majority of indiana built toyhaulers, it's either 2500 lbs or 3000 lb distributed evenly. for atc, sundowner, merhow, lakota etc etc it's 7k lbs to 11k lbs. i load a 1960 lb sand rail in mine. you can see the door bow a bit and mine is rated for 3k lbs. my cargo area states 2400 lbs on the wall. i removed the happy jack beds and couches so i could add 750 lbs to that #.
- cwill925ExplorerMy ramp is tagged 3000 pound capacity, but garage area is tagged 2000 lb capacity. Check the Spark specs, I saw two spec sheets that listed the base weight over 2200 lbs.
- azdryheatExplorerDepends on the toy hauler. I think mine is 3,000 pounds but it's built to be a patio, too.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
