SpencerRB
Nov 19, 2013Explorer
IOWASTROKER wrote:
Our 2012 3950 Cyclone has no factory belly "cardboard". There was no insulation, unless you consider the black plasic below the plywood as insulation. 3 3-inch holes cut on bottom side of main heat trunk...but the way the belly "hangs down"...guarantee it will not keep the tanks from freezing.
I threw the belly cardboard away. 1.5inch styrofoam on inside edge of the Ibeams, then 1.5 inch styrofoam with ProPanel II steel panels screwed to bottom of I beams. Dropped a remote thermostat sensor into basement: usually 8-10 degrees warmer than the living quarters:))))))
I'd love to see pictures of this too.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
