- deloshollyExplorerI am not sure what walls you refer to, inside or outside, but Livin Lite's toy haulers are:
Exterior?/?Construction Features
EXTREMELY LIGHTWEIGHT DESIGN – Towable by Most Trucks & SUVs!
6-Sided Aluminum Super Structure
5" Double Aluminum Frame w/3" Tongue Tube Middle Rail – 3-Tier Frame
Composite Material throughout unit (water and mold resistant)
All Aluminum Floor Decking w/D-Rings (can order w/no lino)
Vacuum Bonded Walls, Laminated w/Azdel 3-Tier Glue Process (stronger, more durable)
.40 Aluminum Siding w/Full Body Automotive Paint (6 Color Choices)
6-Sided Block Foam Insulation including Front Radius
Alpha Superflex® Roof w/12-Year Limited Warranty (more durable, less chalking & streaking)
Dexter® Torsion Axles
Auto-Adjusting Brakes w/Easy Lube Axles - MidtownExplorerI have a feeling it's just going to be the ones that offer a toy hauler in 1 or 2 floor plans.
- BumpyroadExplorerif a used RV, Ascend did.
bumpy - tinner12002ExplorerCoachman uses it according to web search.
About Fifth Wheel Group
