dsrace
Mar 02, 2014Explorer
there are many many options for 3/4 tons just have to look up what your truck is rated to tow for trailer max lbs. I would suggest a fifth wheel since they tow a lot better than a bumper hitch but that's up to you. fifth wheel towing capacity is usually higher than tt but you'll have to look that up to be sure. the pin weight will be the second concern and you'll need to know you payload capacity for that one like the above post's stated. I would guess that if you buy a fiver th'er with an empty weight of like say 7k lbs to 8k lbs and if you not loading more than 2k lbs of toys and don't tow with water in the tanks you'll be fine but real #'s will tell you for sure. I towed my 2011 wolf pack fifth wheel 295 th'er with my old 1995 ext cab 2wd diesel with no real problems loaded with an 1200 lbs sand rail and prob 500 lbs of tools then plus food and gear. prob 10500 lbs loaded but when I went to my current f350 dually it is a better towing experience.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
