high desert wrote:
BoonHauler wrote:
I thought I'd update this post as I've almost completed the power distribution system for the Hauler I'm building. I do have a few questions for those that have Magnum Inverters installed in their rigs.
What have you set your Low Battery Cut Out (LBCO) set at?
And what voltage do you recharde at?
I read where PianoTuna mentioned 12 volts but just wanted to check in with all you experts.
I'm interested in hearing the answer to those questions as well. I'm in the middle of installing a Magnum MS2812 with a Mini Magnum Panel in my toyhauler as we speak.
High Desert:
I spoke with the tech guys at Magnam and they recommended 10.5 VDC for the LBCO so that's where I'm set for the time being but there's still a lot of testing to be done before I drive a stake in the ground.
As for the recharge voltage, I have information from the manufacturer (Crown Battery) but it's all kind of greek to me. They do state specific gravities though and I'm going to run my battery bank down to 75% (on the TriMetric) and verify that viva specific gravity and then recharge.
I'll post the information here as well.
