jmtandem
Dec 31, 2019Explorer II
Estimate about twenty percent of a fifth wheel's weight on the pin plus the weight of the fifth wheel hitch. So if the hitch is 100 pounds or so and the pin is 3200 pounds you are well over payload on your truck. A fifth wheel at 16,000 pounds is definitely in one ton territory and a dually will give you even more stability and payload. As to your question about the difference between GVWR and axle ratings, GVWR is always lower than combined axle and tire ratings.
About Fifth Wheel Group
