Cummins12V98 wrote:
B.O. Plenty wrote:
The Tri-Glide portion is just a different jaw. I can be added to a std Trail-Aire hitch. I have a Tri-Glide it works okay. I'm not sure it's worth the extra investment. They aren't cheap. I would look at your hitch and make sure all is well there first. Trail-Aire is owned by Lippert. You should be able to order the Tri-Glide portion from any dealer that sells the hitch. Prices will vary greatly from one source to another. You might try Lippert direct.
B.O.
Do you get a clunk when starting and stoping with the TriGlide?
I do get a slight clunk at times and my Super Glide is adjusted up tight. I'm not 100% sold on the Tri-Glide jaw although it does tow nice except when starting or stopping. I've never towed without it except with a standard pin box without air ride.
B.O.
