woodsmitch's avatar
woodsmitch
TrailAir pinbox
So I replaced the pinbox on my 5th with a TrailAir box. I am happy with the way it took care of the up and down shock but now I have a chucking problem. When I ordered it (etrailer.com) the triglide model wasn't available from them. My question is where can I order the tri-glide attachment for my hitch. I haven't found anywhere that shows this part. Ultra-fab says it can be installed on any trailair pinbox.
  • Randu wrote:
    Do you have air pressure set so you can see top of arrows? I found that for me I get a better ride if I keep the pressure set so the trailer floats from bottom of arrow head to about 1/2 inch below on normal highway driving. Randu
    I do about the same. Rides rough if I raise it to the top of the arrowhead..But then who knows if the decal placement is very consistent.
    B.O.
  • donn0128 wrote:
    The clunking is caused by too much slop between the hitch pin and the hitch jaws. Depending on your brand of hitch there should be some adjustment to take the slack out. On my hitch there is a 1/2 inch bolt on the truck cab side of the head that i can adjust to remove the slack. Just be careful not to make it too tight.
    He said Chucking not clunking.
    B&W you will have no Clunking!
    I bought mine thru lippert. My Wife has a business license and saved a ton of money. But I honestly don't know if it did a darn thing!
    I think you need to look at what else might be causing the chucking.
  • I ordered the triglide through a local rv repair shop directly from lippert. You remove the nut at the top of the airbag (by the fill valve), then remove the bottom of the shock. The lower jaw swings down, and you remove the pivot at the rear. Reinstall the same way.
  • Do you have air pressure set so you can see top of arrows? I found that for me I get a better ride if I keep the pressure set so the trailer floats from bottom of arrow head to about 1/2 inch below on normal highway driving. Randu
  • The Tri-Glide portion is just a different jaw. I can be added to a std Trail-Aire hitch. I have a Tri-Glide it works okay. I'm not sure it's worth the extra investment. They aren't cheap. I would look at your hitch and make sure all is well there first. Trail-Aire is owned by Lippert. You should be able to order the Tri-Glide portion from any dealer that sells the hitch. Prices will vary greatly from one source to another. You might try Lippert direct.
    B.O.
  • The clunking is caused by too much slop between the hitch pin and the hitch jaws. Depending on your brand of hitch there should be some adjustment to take the slack out. On my hitch there is a 1/2 inch bolt on the truck cab side of the head that i can adjust to remove the slack. Just be careful not to make it too tight.
  • Contact Ultra Fab & ask where it can be purchased! :)
