bobx2 wrote:
Francesca Knowles wrote:
It's my understanding that unlike with torsion axles, leaf sprung axles equalize the load between them if the trailer's off level.
I could be wrong; I'm sure that if so someone will post and say so!
I too would be curious to know if that is the case. The center mounting point is called an equalizer, so it would seem that the purpose would be to equalize the load on both axles. I would imagine that in an extreme case there would be different loads, but a couple of inches, I don't know. It's tough to get them level with the height of todays trucks.
Easiest way to find out is to weigh the 5'er. I run 1" high and have weighed both axles. 50lbs difference. I can't say if it's from the nose being 1" higher or just the way it's loaded. Either way it's a wash in my book.
