Baja_Man
Dec 23, 2015Explorer
Trailer lights - Need Assistance
I plugged in my trailer plug to truck receptacle. All lights work correctly except for the right rear taillight that I just replaced. The wires appear to be reversed. When running lights are on the stop (brighter filament)light is on making that taillight brighter than the other one.
I did replace the tail light housing and lens but there are only three wires (brown for running lights, Green for stop/turn, and white for ground. I even put the old housing back obn to check and still does not correct problem.
I also hooked up my boat to see if truck receptacle was wired OK and the lights work perfect.
I can't recall if the lights worked OK before since I only trailered once for a few miles.
If I reverse the brown and green wires at tailight, all works well. Not sure if that is the correct solution.
Help!!!
Thanks
Help!!!
Thanks
