Coach-man
Jul 17, 2015Explorer
Not sure if you have found your problem, but check your convertor, there is usually a reset button if for some reason it got overloaded. Do the reset and check voltages starting at the convertor. If the two large 6 volt batteries got really discharged and you plugged into shore power it could have triggered the reset? Good Luck!
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
