CKNSLS
Mar 10, 2015Explorer
Me Again wrote:avvidclif1 wrote:
To Chris:
I used the 16" E Radial Trail on my last 2 trailers(same set). While not heavy it weighed 11k+ and I had no problems in 10k mi. I will probably put them on my new one which will put a load on them, no scaled weight yet but guessing at 13.5-14k. Shipping was 12.8k.
Two 7K axles and ST tires, good luck with that! I would be looking at GY G614's or Sailun S637 if it was mine. But hey you can keep us informed on how it is working over the next few years. I would at least get the LRF ones and only tow at 60 MPH like CKNSLS. But TH guys tend to be weekend warriors and always in a hurry. Chris
You know Chris-it sounds like your "softening a little bit". I would say that anybody running 12,000 pounds and under are OK with a Good ST tire with the proper ratings. At this point my choices are (in no particular order) Maxxis, Carlise RH, and Tow max.
Anything over 12,000 pounds they should look at your recommendations.
However, I still maintain no one has any business pulling much over65mph IMHO.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
